Old 04-27-2009, 01:19 PM   #1
IMS Retrofit Upgrade
http://www.cheetahonline.com/ims.html
I installed it when I did the RMS and flywheel replacement, so did a write-up on it.
Enjoy...
cheetah is offline   Reply With Quote
Old 04-27-2009, 03:12 PM   #2
Engine Surgeon
Great!!! Glad you had a good experience with our development! We were happy to help you!
Old 04-27-2009, 03:17 PM   #3
Lil bastard's Avatar
Excellent write-up!!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 04-27-2009, 03:38 PM   #4
A question -- please explain why you had damaged bolt hole threads?
I don't see how the threads could be damaged enough to retap a larger size.
TIA for your reply,
Ed
Sboxin is offline   Reply With Quote
Old 04-27-2009, 04:32 PM   #5
Thanks for sharing. What makes it more interesting for me is that its beyond my knowledge. Learning is a good thing.
Jim
-- 02 Boxster S
-- Black/Black
-- Sideskirts/PSE
Sputter is offline   Reply With Quote
Old 04-27-2009, 04:52 PM   #6
cheetah,
Awesome, thanks for the write up. I plan to do this when I redo the cluch / Flywheel / RMS.
rob76turbo
Current Porsches: 2002 Boxster S (Speed yellow)
Past Porsches: 1972 914, 1987 944S, 1976 930, 1986 951, 1999 986, 1992 968, 2001 986 S, 2006 Cayman S, 1986 951 track car, 2001 986 S, 2005 Cayenne
rob76turbo is offline   Reply With Quote
Old 04-27-2009, 05:17 PM   #7
Coming out, the bolts just didn't seem right. I tried torquing down on them, and on two of them it seemed like they were about to just strip the threads out of the wall. One actually did this. An M6 only has a thread depth of about 1/2 mm (~.020"), so being bolted in Aluminum doesn't give a lot of confidence.
On an area so critical to the life of an engine that is so expensive to replace, better off safe than sorry. This way, I won't worry about if they will come loose.
I don't know if the threads are prone to problems, but by looking at the design, that area does support a fair amount of force, so I don't know if it can ever cause the threads to get worn.
TIA for your reply,
Ed
