Old 03-25-2009, 07:51 PM   #1
Antifreeze Smell and Vapor in Cabin
I have a 1998 Boxster/Manual/ with 107K for miles. I was wondering if anyone has experienced:
1. A vapor/antifreeze smell coming from inside car
2. I have to turn the thermostat down to 66 degrees before the A/C feel cool
3. A bit of a belt squeak from the engine compartment
Kind of sounds like a thermostat and water pump but I cant explain the vapor/ant-freeze smell coming from the vent.
Any help would be appreciated.
jjordan23 is offline   Reply With Quote
Old 03-25-2009, 08:00 PM   #2
Lil bastard's Avatar
3 separate items.
Leaky hose (notorious item on Porsches which use spring clamps - always replace with worm clamps, aka screw type), Leaking heater core (Heat Exchanger in Porsche lingo) - replace, or cracked coolant reservoir - replace. In that order.
AC... cracked hose or bad 'o' ring - replace and recharge system.
Squeak... replace polyrib belt, belt tensioners and/or waterpump.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 03-25-2009, 08:15 PM   #3
Thanks for your quick reply now I will get an estimate on those items. The vapor and anti-freeze smell is coming from the heating/ac vents is the heater core in the front of the car?
Old 03-25-2009, 08:22 PM   #4
Yep...
AC issue could also be a cracked or punctured condensor... have the system pressure/leak tested.
1976 BMW 2002
1990 BMW 325is
Old 03-26-2009, 07:46 PM   #5
Thanks again will keep you posted on the outcome
Old 03-27-2009, 03:22 PM   #6
I just changed my heater core. There are 2 hoses that feed it behind the battery. A new one is pricey, I got one from a wrecker that is like new with warranttee on the auction site.
suburban99 is offline   Reply With Quote
