Old 12-03-2008, 05:00 PM   #1
Replacing pads w/o machining the rotors
...just want to see what people's experiences here are when replacing the brake pads without machining the rotors, with rotors still above minimum thickness?
I am basically replacing the rear pads with OEM at 60k, but every now and then i hear from my friends that machining the rotor at this point is useful. They claim this is because the old pads usually leave a coat of material on the rotor, which may not be compatible with the new pad materials.
Any pointers appreciated~
Maxodus is offline   Reply With Quote
Old 12-03-2008, 07:34 PM   #2
I don't think I'll ever machine a rotor again. If its that bad it will just get replaced. I just put new pads on all 4 corners without changing the rotors. Pads bedded in well and breaking is much more assertive than before. I of course also did a full flush and bleed with good fluid.
Unless there is a large amount of grooving you should be good. Just make sure the rotors are in good shape and smooth with no cracks.
2005 987 - 112K miles PASM + 6-speed - Daily Driver
1988 944 - 240K miles- Race Car
1974 911 Targa - new project
2009 Triumph Street Triple R - 27K mi - Blazen Orange
1976 Ford F250 camper special - tow vehicle
944boy is offline   Reply With Quote
Old 12-03-2008, 07:54 PM   #3
Porsche says not to turn rotors on our cars. Just replace them every 2nd or 3rd pad replacement.
The original rotors on my car lasted 100k believe it or not.
Old 12-03-2008, 08:50 PM   #4
Some suggest to sandpaper the rotors when switching to a different pad compound.
2003 Boxster - Sold but not forgotten
timothy is offline   Reply With Quote
Old 12-03-2008, 11:10 PM   #5
Lil bastard's Avatar
ABSOLUTELY!!!
If you 'mic' your rotors, and they're within spec (assuming there is no perceivable warparge), you do want to remove any traces of the old compound before adding new pads.
Brakes work 'best' when the pad lays down a layer of material on the rotor so you get material-to-material contact.
Sanding the rotors with 80-40 grit sandpaper removes the old compound, leaving a fresh surface to build-up a layer of the new pad material during the bed-in.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 12-04-2008, 10:28 AM   #6
thanks guys~
...awesome feedbacks, thanks guys. The idea of sandpaper sounds great, i'll definitely give it a try this weekend~
2003 Boxster 2.7L 5 spd
Old 12-04-2008, 11:45 AM   #7
I would not bother scrubbing with sandpaper. If you properly bed the pads with a proper break-in procedure, they'll be fine.
Stoptech has some great articles online about brake theory, for instance, here's their take on proper bed-in procedure:
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
2005 Seal Grey Boxster S
987 Amberectomy
eslai is offline   Reply With Quote
Old 12-26-2008, 02:57 PM   #8
New Pads /Old Rotors
This all sounds like good logical advice; and best of all IT WORKS! I'm about to be doing this same operation. My question is; which brand / type of pads did you use? And are brake wear sensors really necessary? as some pads don't have the provision for them. Any help or strong opinions will be appreciated.
Thanks,
Andy
superglide is offline   Reply With Quote
