Old 01-03-2009, 06:01 AM   #6
ppbon's Avatar
Originally Posted by Stefan (Boston)
I'm pretty sure that Porsche recommends you only remove the diagonal braces when the car is supported at the four jacking points. Otherwise (they suggest) you might need an alignment. I personally don't see how this could be so but it is from the horse's mouth for whatever that's worth.
I had a customer that brought in his car because he couldn't put the skid plate back on after he removed the diagonal cross braces.
He had changed the tranny oil with the car on ramps (suspension loaded).
I had to raise it off the ground on stands and practically loosen everything again before the skid plate would fall into place.
If he would have installed a TechnoBrace, things wouldn't have shifted.
Happy Boxstering,
Pedro
ppbon is offline   Reply With Quote
