Old 09-19-2008, 03:18 PM   #1
Another survey--IMS failure
There's been a lot of chatter on pete's board regarding IMS failures and it seems that the frequency of this failure is going up based on the posts I see on it.
How about a survey on this forum, similar to the one on the RMS? There's probably a better way of doing it compared to the last time--i'd appreciate your thoughts on it.
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
MikenOH is offline   Reply With Quote
Old 09-19-2008, 03:30 PM   #2
I will keep it simple because I've kept an eye out on this stuff for 2 years now.
3.2L ARE THE ONES THAT HAVE IMS FAILURES MOST OF THE TIME.
Just ask Chris Zang, Dennis(PPBB) and all the 996(3.4L) owners on rennlist what happened to their engines. IMS failures.
The 2.7L tend to be safe because they don't have the same IMS as 3.2L & 3.4L engines.
Old 09-19-2008, 06:16 PM   #3
Sorry Blinkwatt, I have to disagree with you on this one. We just had a thread about engine failures at
Shortlived Boxster engines survey
This thread showed about 25 failed engines and of these, 20 were 2.5/2.7L engines. The failures were either slipped cylinder sleeves or IMS failures. The reported MYs ranged from 1997 though 2003 and the mileage reported at time of failure was all over the odometer, some with low miles, others with 60K plus miles. No real pattern.
For the 5 or so 3.2L S model engines that failed, there was no real pattern on the odometer reading when the failure occurred either.
At any rate, with thousands of Boxsters produced, hearing about 25 with failed engines in one thread tells me only one thing... there's not much data here to make a statistically reliable judgment about any of it.
Rich F
somewhere
past: 2000 Boxster S
past: 2010 Boxster S
turbo23dog is offline   Reply With Quote
Old 09-20-2008, 01:26 AM   #4
Read the original post again,the original poster said IMS failures,not cylinder wall failures.
Cylinder wall failures tend to happen to 98'-99' 2.5L,IMS tend to happen to 00'+ 3.2L. Cracked heads have also been an issue with 3.2L,not not anywhere near as bad as IMS failure.
Yes there is a common pattern with these engines,most engine failures on M96 engines happen at 60k or less mileage unless you name in dennis from PPBB where it happened around 65k. Poor guy has had at least 2 engine failures on his Boxsters.
Make friends at shops,track meets, everyone who works on these cars,talk to them,they know there is a problem. I have a friend who was a mechanic at Niello Porsche that said he wouldn't even touch one of these cars off work. He said he sees way too many repair bills for engines costing over $15k.......
Old 09-20-2008, 07:59 AM   #5
Brucelee's Avatar
I don't see any reliable way to get good stats. The only folks who have a decent shot at doing that are not talking.
So this stays in the land of conjecture.
Rich Belloff
Old 09-22-2008, 05:24 AM   #6
There Is No Substitute.
rick3000's Avatar
The problem with an online survey is that your going to get bias results. People who have never had a problem with there car have no reason to google boxster forum and come here, while someone with a problem (say an engine failure) is much more likely to google their problem and come here. Which means that your going to get a lot more people with engine failures posting than people who don't have problems.
There have been something like 200k Boxster's sold worldwide, if you look at all the forum failures reported your still no where near a significant number of failures, even though they shouldn't be happening in the first place.
Also, IMS is very, very rare on pre-'01 Boxsters due to the updated IMS in those and latter cars. But the pre-'01's tend to have more RMS.
Old 09-19-2008, 03:52 PM   #7
gregdacat's Avatar
I've got a 2.7 with 67k on it going strong with no IMS issues. I will be changing the oil in 500 miles and sending it off to Blackstone for analysis. I'll let you know if they say there is a major repair in my future.
Greg
2002 Triple Black, Desnorkled, Bumper Plugs, LN IMSB Upgrade
gregdacat is offline   Reply With Quote
Old 09-19-2008, 06:14 PM   #8
Good man, blinkwatt
I know these surveys --the online ones--can't be as reliable as the the surveys done by market research companies that are mailed in, but we need a way to keep out bogus info as best we can. Anyway we can get details via the PM messages to make sure the info is qualified somehow?
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
Old 09-19-2008, 06:45 PM   #9
My '02 Boxster S saw a replacement motor and 6-speed under factory warranty at 15k. The records do not indicate a specific reason why, but one can venture a guess. Now, 38k later it runs like a champ.
HB986 is offline   Reply With Quote
