Old 08-02-2008, 03:39 PM   #1
Best Headers for 2002 3.6L in Boxster
What is the best header that will fit in a 2002 Boxster S with a 2002 996 3.6L? performance is the goal and past emissions. Is the SCargo the best? money is also a factor too.
Ride Big and Tall or Not at All
m2speed is offline   Reply With Quote
Old 08-02-2008, 05:08 PM   #2
Fabspeed headers are the best.
Old 08-03-2008, 01:12 AM   #3
Thats a difficult question... ideally since you are running .4 more liters, you would want headers bigger than those made for a 3.2 or 2.7... but 996 headers do not fit under a Boxster... so just find the biggest you can.... BUT you want to pass emissions... thats a whole other can of worms which would start with does your state check emissions? or do they rely on the OBC? do you want to run your secondary cats? etc etc... that answer can be searched on here...
Lexington, KY Go CATS!
http://i187.photobucket.com/albums/x...s/DSCN0406.jpg
2001 986S... 3.6 swap (yep 7.2->7.8), PSS9's, GT3 seats, OEM 986 Carrera 5-spokes, and much more http://i187.photobucket.com/albums/x...me/burnout.gif
1987 928 S4 white on red and... dead
2004 Chevy Surburban... drinks gas like its cheap or something
easyc is offline   Reply With Quote
Old 08-03-2008, 01:23 AM   #4
Well you made a very good point about missions. In Austin they only check for codes on OBD II cars. Older ones they do the sniff test. I think that is correct anyway. If so I could forgo the secondary cats and use thoses bypass sensor adaptors too keep the trouble codes away.
Old 08-03-2008, 10:18 AM   #5
Any header made for a 986 is too small for the 3.6. With the 3.6 Porsche enlarged the exhaust ports size significantly. Previously the 996 3.4 and 986 engines used the same size exhaust ports so using a set of 3.2S performance headers was a good solution. Not so with the 3.6 and 3.8 swaps. This obviously ignores the primary size and length, which are also wrong for a 3.6 on the 986 based headers.
-Todd
Current Cars:
1989 911 Targa
1984 944 Original Owner
1971 911T
tholyoak is offline   Reply With Quote
Old 08-03-2008, 01:51 PM   #6
-Todd
So what is the solution? Does anyone make a good header for the 3.6L to 3.8L in a 986?
