Old 07-16-2008, 01:41 PM   #1
Send a message via AIM to blinkwatt
New Rotating Sound
Cars info; 01' 986 S,6-spd,56k
Yesterday while driving I noticed a new sound. It sounds like a wheel bearing issue almost but there isn't any other symptoms of a wheel bearing failure(I've had the front passenger one go out). The sound is the same no matter which way I turn,how hard I brake, it just speeds up according to speed. Also,the car feels normal,I can't feel anything from it when driving. Anyone have any ideas? I know it's coming from the driver side.
If you need any other info let me know and I will post the answer.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 07-16-2008, 01:53 PM   #2
bmussatti
Guest
Posts: n/a
Blink, could be something as simple as a small stone/rock stuck somewhere on the wheel/rotor.
Old 07-16-2008, 01:58 PM   #3
I wouldn't doubt it. Just from looking under the car real quick everything looks ok,nothing too obvious. I will remove the wheels this evening and check it out. Just trying to get all suggestions/input in before I decide to get dirty.
Old 07-16-2008, 09:15 PM   #4
I just got done R & R the front driver wheel. I found the rotor screws completely loose. I will drive the car this evening to find that hopefully the sound is gone.
Old 07-17-2008, 12:04 AM   #5
I fixed it. The driver side e-brake cable that leads from the hand brake in the interior was rubbing up against the wheel and tire.....Guess 18x10" w/ 47mm offset w/ 275 tires doesn't leave much space.
Zip ties are awesome!
