Old 06-18-2008, 10:48 AM   #21
Originally Posted by John V
The urethane instructions suggest that it takes 24 hours to fully cure. I wouldn't want to install it prior to the urethane fully curing.
anyone can do what they feel comfortible with doing since its there car, Me on the other hand had no choice but to install the mount after the outter surface hardened 20-40 minutes later since this is my only car and theres no way i'd let my baby spend the night in a mechanics shop unless a last minute clutch, transmission or engine swap was in order. To each his own!
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 06-18-2008, 11:51 AM   #22
Besides looking at the mount after removing it, can you look at the mount as installed and tell if it has failed?
Regards,
mike
derb is offline   Reply With Quote
Old 06-18-2008, 12:00 PM   #23
Hmmm, not really cause its got these rubber flaps that shroud around the mount so you cant really see it, You'd have to remove it... If you have a hard time accelerating without grinding 2nd gear while you shift, Chances are that your engine mount is bad.
Carlos J Cazares
Old 06-18-2008, 12:22 PM   #24
Thanks CJ.
No problem from 1st to 2nd gear. I just have the occasional grinding when shifting from 2nd to 3rd. Synchro?
Old 06-18-2008, 12:26 PM   #25
Originally Posted by derb
Thanks CJ.
That im not 100% sure of but could still be an engine mount problem... would anyone else like to chime in with more info?
Carlos J Cazares
Old 06-19-2008, 05:44 AM   #26
I would think anyone would want to do a job one time properly rather than do it once and have to do it again because they were rushing. Like you said, though, to each his own.
John V is offline   Reply With Quote
