Old 06-10-2008, 05:12 AM   #1
Code
What is P1124 and P1126 codes?
Yoslack is offline   Reply With Quote
Old 06-10-2008, 06:47 PM   #2
depends on dme version, which depends on engine and model year.
brp987 is offline   Reply With Quote
Old 06-10-2008, 08:39 PM   #3
1998 boxster base model
Old 06-11-2008, 05:47 PM   #4
from bentley:
1124 - fuel pump output stage
signal implausible/open circuit/no signal
short to ground/below lower limit/lean mixture threshhold
short to B+/above upper limit/rich mixture threshold
(yes, all 3 are listed - don't ask me)
1126 - oxygen sensing adaptation, upper load range, cyl 1 - 3
good luck
