You WANT the forward O2 sensors in the exhaust stream. This makes corrections in mixture during closed-loop operation. Don't use a cheater on these, use a normal bung.
For the rear sensors, if you can't get a reflash, you can replace the sensor with a circuit that tricks the ECU into thinking all is well. I've posted it here before if you're interested you should be able to search for it.
