Old 05-18-2008, 02:13 PM   #37
Kirk
Originally Posted by tholyoak
There are actually a few 'ROW' programs, but I assume the one you are interested in, is the one that doesn't use post cat sensors. This obviously only use pre-cat sensors to control the mixture, ignores the need to depress the clutch to start the car, doesn't use the air pump for cold starts. Also it is virtually impossible to get a CEL as the tolerances are much greater on the ROW program. Those are the differences off the top of my head.
Todd, I appreciate all of your input here! Do you see any problem with running the ROW program you described on the crappy 91 octane gas in California? Also, can you tell me specifically which program I would load onto my 2000 Boxster S (manual transmission) DME to get this ROW setup? Does the program have a file name or title that I can go by? I'm going to see Loren in a couple weeks and I'm sure he could do this for me with his PST2, if he knew which of the programs to load.
Kirk is offline   Reply With Quote
