Old 04-24-2008, 08:43 AM   #2
After a number of drive cycles if the fault is not detected again then the fault code is deleted from the DME and the light goes off.
So you must have driven the car enough times and the fault was not detected again. So the fault code erased itself.
At my local dealer they like to see your car when the check engine light is still on.
Tool Pants is offline   Reply With Quote
