Old 03-31-2008, 08:00 AM   #1
SBD
gt3 lower control arm install??
I am wondering if anyone has info on doing this install? It looks pretty straight forward.
My main question is what degree shims to use? I am hoping for 2.5-3 neg. camber.
SBD is offline   Reply With Quote
Old 03-31-2008, 08:34 AM   #2
It will depend on other factors if you will be able to get that much negative camber without rubbing. I am running 2 degrees negative camber on the front with the GT3 Control arms... at 2.5 Degrees I had rubbing issues.
__________________________________________________
Marc
2001 Boxster S
Mostly stock... except for all the things that are changed.
www.dexterautosport.com
http://www.pbase.com/image/89146172.jpg
mdex is offline   Reply With Quote
Old 03-31-2008, 01:24 PM   #3
Cool
I have GT 3 lower controll arms. With 245 X 45 X 17 slicks mounted on 8.5 wide wheels with a 5mm spacer along with PSS9's I get a slight rub with 2.5 degree and a bad rub with 3 degrees.
catmanluge is offline   Reply With Quote
