Old 03-31-2008, 07:34 AM   #2
mdex
It will depend on other factors if you will be able to get that much negative camber without rubbing. I am running 2 degrees negative camber on the front with the GT3 Control arms... at 2.5 Degrees I had rubbing issues.
__________________________________________________
Marc
2001 Boxster S
Mostly stock... except for all the things that are changed.
www.dexterautosport.com
http://www.pbase.com/image/89146172.jpg
mdex is offline   Reply With Quote
