		|  03-24-2008, 05:13 PM | #1 |
	| Registered User
				Box S Oil change
			Ok we're changing the box S oil this week.  I did do a search and found out most of the stuff, its kinda hard because a search using the word "oil" isnt allowed because its not enough letters.
What kind of filter do I need? Recommended oil is Mobile 1 0W 40 right fully synthetic? I need about 9 quarts?  If I can't find 0W 40 then   5W 40 is next best? I seen brucelee uses Redline. What are your experiences on which is better? I'm in Ohio so we definately have cold winters, although I don't drive it in the winter, stored inside a semi heated garage.  thx
				Lamborghini Murcielago (current)
Supercharged Viper SRT-10 800 HP Special Edition #49 of #50 (current)
Ferrari 360 Spider
Lamborghini Diablo VT Roadster
911 Cab
Boxster S (current)
08 Hummer H2 (current)
BMW Z3 (current)
Limos in Ohio and PA - First Class Limo Columbus Limos
http://pteam.net/avatar3.jpg
my car collection   *Porschephiles agree, Desnorkify your Porsche!*
		|  03-24-2008, 05:38 PM | #2 |
	| Registered User
5-40 synthetic should be fine. I always bought OEM filters from dealer.
good luck.
				Rich Belloff
		|  03-24-2008, 05:50 PM | #3 |
	| Registered User
			Do you have a part number or brand type of filter? I'm not going to the dealer so I need to buy it somewhere. Thx
Ferrari 360 Spider
911 Cab
Boxster S (current)
BMW Z3 (current)
		|  03-24-2008, 06:03 PM | #4 |
	| Registered User
				 Do you have a part number or brand type of filter? I'm not going to the dealer so I need to buy it somewhere. Thx |
Try pelicanparts.com . They should have the oem filter for +/- $10.
		|  03-24-2008, 06:40 PM | #5 |
	| Porsche "Purist"
			I bought a lifetime supply:  Like these
				__________________1998 Boxster with 7.8 DME, 2005 3.6 liter/325 hp, Variocam Plus, 996 Instrument panel
 2001 Boxster original owner.  I installed used motor at 89k.
 1987 924S.      2002 996TT.        PST-2
 Owned and repaired Porsches since 1974.  Porsche: It's not driving, it's therapy.
		|  03-25-2008, 01:46 AM | #6 |
	| Registered User
			the M1 5w-40 will be just fine.
 while the redline is a great oil. its not a porsche certified oil.
 if you can find it, try something like elf/total. it will be harder to find than M1 though.
 if you are going to the dealer, then just tell them the year, make model, and they will tell you what you need. you can also try suncoast.
		|  03-25-2008, 08:51 PM | #7 |
	| Registered User
			If you have not changed your Porsche oil before, keep in mind that it does not use a regular oil filter. The o.e is just a filter filament replacement and o ring which means you also need to get the correct oil filter wrench (cap style) and you actually need about 10 quarts as 9 is not enough.
		|  03-27-2008, 05:52 PM | #8 |
	| Registered User
			You can purchase the oil filter wrench for less than $4.00 at Autozone or local auto store. While you're there, you might want to pick up a >10 quarts oil pan for about $10.00.
I, too, purchased the oil filter and crushed ring on Ebay. (re: I think I bought a lot of  four for less than $35.00).
As for the oil, as box2000 noted, it's actually 9 and 1/2 quarts (0w-40 or whatever your preference). BTW, when you check the oil level, to the right of your odometer, it should be one bar less. If all the bars are lit, then you've overfilled.
Enjoy!    |
		|  03-27-2008, 06:10 PM | #9 |
	| Registered User
			According to Porsche TSB 1701, the correct oil capacity for a change w/ filter is 8.75 liters (9.25 quarts).
		|  03-27-2008, 06:14 PM | #10 |
	| Registered User
			"According to Porsche TSB 1701, the correct oil capacity for a change w/ filter is 8.75 liters (9.25 quarts)."
LOL!! I stand corrected!!    |
		|  03-31-2008, 03:09 PM | #11 |
	| Registered User
			Yes.  My Boxster S takes 9.30 quarts. You of course need to buy 10 to get that 0.30 of a quart.  Definitely buy a high quality (OEM) oil filter and the 20 cent crush ring for the drain plug.  The 0W40 Mobil 1 is supposedly to allow the oil to flow much more quickly on a cold start.  You know what they say, that first start is where all the wear occurs when your cylinder walls are dry from the car sitting and the oil all running back into the pan. Also reduces valve train noise per the PCA Q&A Tech section.
				__________________http://i25.tinypic.com/20aq3wn.jpg http://i26.tinypic.com/2zguetx.jpg http://i28.tinypic.com/2jdi1ok.jpg
2000 Boxster S: 18" Turbo wheels w/color crests, Litronics, Onboard Computer, Traction control, Cruise, Painted rollbar, Leather interior, Aluminum package, headlight washers, Porsche GT3 seats, windstop, Hi Fi six speaker amp package, DSP, CDR 220, Limited Slip, side airbags,  BK Rollbar extender.
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 |  |  |  All times are GMT -8. The time now is 02:58 AM.
