Old 03-29-2008, 02:12 PM   #10
If the fuses in the fuse panel are ok there is also a fuse in the back of the radio. If you slide the radio out and turn it around it is obvious where it is. It is only 7.5 or 10 amps depending on the radio. If the radio is not powering up at all this is probably your problem.
Techbones is offline   Reply With Quote
