Old 10-12-2004, 11:04 PM   #1
engine light
has anyone have the same problem as i got .the engine light on .porsche dealer found out that *178 camsharf position adjustment bank 2 p1539 actuator---another one is *104 cv faulty p1689 ecm both required 10 hr's of labour $$$$$$$$,so i have ask the machanic ,how soon this need to be done .apperiantly he told me that u might not even notice at all so just drive it hoping some one have a better answer ,cause i did went throught the whole forum didn't come across with the same topic as mine .:dance:
911sc is offline   Reply With Quote
Old 10-14-2004, 12:28 AM   #2
The fault you are getting means your Cam Tensioner has problems which it cannot compensate for by adjustment.
Driving your car with this error is inviting a major failure [sucking a valve].
I would not drive this car until you find a competent mechanic to evaluate your problem totally.
Short of running your Boxster without oil, there is not much worse then sucking a valve.
BTW - there is a TSB on this type of CEL.
What year is the Boxster.
I just noticed your name 911SC - do you remember the Carrera chain tensioner upgrade. This is telling you you are about to have one of those failures, if the CEL P code is dead on.
Scott
mrmickeymouse is offline   Reply With Quote
Old 10-14-2004, 06:03 AM   #3
it's a 97 ,yes i do know about the 911sc upgrade chain tensioner,is this a common problem that most of the 97-99 got ?
Old 10-14-2004, 10:59 AM   #4
No, I have heard about it a few times, and one person blew his motor because he ignored it.
Rev'd to high [subjective due to the bad tensioners] and that was it - next motor:ah:
I don't believe in dealers, but I would seek someone with a PST2. To verify the codes, or someone with a PST2.
If you send me an PM with your e mail, I will send you the TSB.
Scott
