Old 11-17-2007, 12:10 AM   #1
Brake pads and oil change
Hi all,
On top of new rear tires and a new rear window, I'm about to do an oil change and brake pad change on my 01 boxster S. Can anyone give me an idea on the time it should take and any problems I should look for? I have the Bentley manual and a friend with trade knowledge and hand skills (just don't tell about the hand skills comment!)
Cheers,
-Ozspearo.
'02 Artic Silver Boxster S
"They shall grow not old, as we that are left grow old;
Age shall not weary them, nor the years condemn.
At the going down of the sun and in the morning
We will remember them
Lest we forget"
ozspearo is offline   Reply With Quote
Old 11-17-2007, 03:24 AM   #2
Service times
If you haven't done it before give yourself 1 hr or so for the oil & filter change (mostly to allow all the oil to drain out) and maybe up to 30 mins per set of pads.
Once you do one set the others will be easy. I'm including everything from drive in to drive out in the time.
It's all pretty straight forward, just follow the manual & have fun.
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
Old 11-17-2007, 08:33 PM   #3
Cool, thanks for the reply.
Lest we forget"
Old 11-18-2007, 08:20 AM   #4
Check Renntech.org for detailed instructions on brake pad change with pictures. I'd recommend using OEM vibration dampeners to avoid squealing as the pads wear.
choeglund is offline   Reply With Quote
Old 11-18-2007, 10:34 AM   #5
Oil change is easy. Don't forget to ask for new "crush ring" when you buy your filter. The crush ring is for your oil drain plug and needs to be replaced at every oil change unless you like oil leakage. It's a 20 cent item. Also, don't skimp on oil. Use Mobil 1 as specified. The brakes I haven't done yet. Just turned 39,000 miles on my Boxster S.
http://i25.tinypic.com/20aq3wn.jpg http://i26.tinypic.com/2zguetx.jpg http://i28.tinypic.com/2jdi1ok.jpg
2000 Boxster S: 18" Turbo wheels w/color crests, Litronics, Onboard Computer, Traction control, Cruise, Painted rollbar, Leather interior, Aluminum package, headlight washers, Porsche GT3 seats, windstop, Hi Fi six speaker amp package, DSP, CDR 220, Limited Slip, side airbags, BK Rollbar extender.
2000SoCalBoxsterS is offline   Reply With Quote
