Old 10-13-2007, 12:40 PM   #1
Unhappy 97 Boxster windshield wiper wound't stop
the windshield wipers wouldn't stop on my 97 Boxster.
Windsheild wipers wouldn't stop on "off position". It would only going faster when I turned it up. Everything seems ok and just woudn't Stop in off position.
any one know the problem is? anything helps. Thanks everyone
ericyjt is offline   Reply With Quote
Old 10-13-2007, 02:04 PM   #2
Bad wiper relay.
http://www.renntech.org/forums/index.php?showtopic=11683&hl=relay
Old 05-03-2008, 09:17 AM   #3
new relay changed but now wiper doesn't move when I use the windshied fluid
I got the new relay changed but now when I use my windsheild fluid and the wiper would just stop moving, (stay at same position) , instead of fulid on windshild and wiper moving up and down at the same time.
wiper would still moving after I release using the windsheild fluid.
Old 05-03-2008, 12:15 PM   #4
rdancd816's Avatar
Sometimes the ignition switch can cause these types of symptoms. Have you ever replaced the ignition switch? Just a thought. I have a '97 and the old ignition switch caused a lot of weird stuff on my Box.
"97 Boxster" Guards Red, Coppell, TX 36,500 miles
2010 Mazda CX-7 AWD, Turbo, Grand Touring
rdancd816 is offline   Reply With Quote
Old 05-03-2008, 09:21 PM   #5
No, never change the ignition switch yet.
what kind of weire stuff you had on that old ignition switch?
is it easy to change the ignition switch? that I can do it myself or need speical tool from the dealer?
more informaton would be great. thanks.
Old 05-04-2008, 07:23 AM   #6
I found more information about the ignition switch. I should change it before more problems occur.
but if any one has more information about the wiper would be helpful.
thanks, everyone.
Old 05-04-2008, 09:10 AM   #7
I have not used the windhield washers in a long time. Maybe someone knows if the wipers stop moving while the washer is on, I don't remember.
