Old 09-18-2007, 08:55 AM   #1
Send a message via AIM to blinkwatt
Originally Posted by CJ_Boxster
SO place a peice of tape over it and see if this changes anything for anyone. I did and the car runs better and is finally stopped whining.
How does the car run better?
If there was something meant to be put over it wouldn't Porsche have made some sort of plug for it?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 09-18-2007, 09:24 AM   #2
Send a message via MSN to CJ_Boxster
Well It is suppose to only open and vacum suck the gas vapors when a gas pump nozzle enters the filler neck, You should hear a click when that happens, When there is no gas pump in the filler neck, No vacum should come from this hole... Reason for the tape is, In my case, when the gas pump is reomved from the filler neck, there is still a vacum coming from this vent hole.
In fact when i have my buddy give the throttle a nudge up to 3000 rpms, i can hear whining or howling from this vent. So that is a vacum leak which jacks up the a/f ratio, which makes the car run worse. I can always peal the tape back when pumping gas and reseal it once im done cause thats essentially how it was designed to work.
So somewhere along the lifetime of the car, the vent tube stopped closing itself once i pulled gas pump out of the filler neck
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 09-18-2007, 11:07 AM   #3
boggtown
Guest
Posts: n/a
Well, now you know. (insert gay rainbow star here)
Old 09-18-2007, 11:13 AM   #4
Then "Reading Rainbow" theme song starts and we all learn about volcano's.
Carlos J Cazares
Old 09-18-2007, 05:57 PM   #5
I must be missing something...
I can believe that being a vent, or an inlet for a vacuum, but it seems odd a vacuum system for venting refueling fumes would somehow be tied into the vacuum created by the engine. I mean, you shut your engine off when refueling don't you (i.e. no vacuum when refueling)? I admit I know little about all the compnants that make up an engine, do our cars have an electic vacum pump somewhere?
kabel
Orlando - 99 BMW M Coupe (autocross toy), '11 Mazdaspeed 3 (dog hauler), '99 10AE Miata (the new daily driver)
kabel is offline   Reply With Quote
Old 09-18-2007, 06:21 PM   #6
bmussatti
Guest
Posts: n/a
Ya gotta luv it when you can fix something with a piece of tape!
