Old 08-18-2007, 02:07 AM   #1
Exclamation Intermittent Starter Problem 1997 986 Boxter
Sometimes when starting Boxter (approx once every 20 times) on turning key there is a "split second" delay before it starts. This has happened about 4 times in past 3 months. Has any one else had this problem Can any one give any guidance? .......before it won't start at all !!!!
Brackenbeds is offline   Reply With Quote
Old 08-18-2007, 11:58 AM   #2
Sounds like the ignition switch is starting to fail. It's a cheap part and easy to replace.
wvicary is offline   Reply With Quote
Old 08-19-2007, 01:30 AM   #3
Smile
Thanks for that. Have you had a similar problem. What is involved in replacing it?
Old 08-19-2007, 08:18 AM   #4
Brucelee's Avatar
The stock ignition switch on the Box and 911 is junk. Fortunately, it is a cheap fix.
Rich Belloff
Old 08-19-2007, 08:42 AM   #5
I had a similar problem, changed the ignition switch (under warranty) and it still wouldnt start at times. I finally figured it out....it was the clutch switch that wasnt fully engaged because the floor mat slid up too far. When I pushed the clutch peddle in to start the car, the mat cut short the full range of motion needed to activate the switch, and it wouldnt start.
1999 Boxster
Triple Black (Basalt metallic)
Silver Carbon Fiber Interior,De-Ambered,Euro LED Taillights, Eibach Pro Kit lowering springs,EuroTech 19" wheels/Kumho tires,Turbo spoiler,Clear halogens
Gemballa red face gauges ..(FOR SALE)
http://i28.tinypic.com/2zzlq29.jpg
986speedster is offline   Reply With Quote
