Old 08-03-2007, 03:37 PM   #1
RUF wheel weight?
Hi - I just bought an 02 Boxster S from the dealer. It has these wheels on it. I can not find a reference to what they weight. RUF site was no help. ideas?
thanks!
eVoMotion is offline   Reply With Quote
Old 08-03-2007, 03:41 PM   #2
bmussatti
Posts: n/a
Call this guy at RUF. He can help you and is a good guy.
Wayne Corley - 214-269-1571
Old 08-03-2007, 04:32 PM   #3
thanks!
Man I love the RUF wheels. They're supposed to be pretty heavy. Let us know what you find out!
2003 Boxster - Sold but not forgotten
timothy is offline   Reply With Quote
Old 08-05-2007, 09:00 PM   #4
Thanks! I think they look at bit outlawish on the silver car. Definitely not your "doctor's boxster".
Will update with weights after I call RUF.
Old 08-24-2007, 09:51 AM   #5
thanks for the lead to Wayne. He has been great to help me. Wish he was closer.
Old 08-26-2007, 06:36 PM   #6
Send a message via MSN to Gerardo de Kort
about
Mine are about 10% heavier than stock ones. They are 18 x 10 and 18 x 8.
I weight them with the tires on though (Michelin ps2).
After I put them on the stock box basically did not have the power to break them loose!
Gerardo de Kort is offline   Reply With Quote
Old 08-26-2007, 08:29 PM   #7
Do you have any photos?
Sounds like you need more power. ;-)
Old 08-26-2007, 09:28 PM   #8
Who cares how much those weight,they looks pretty darn awesome!
I would be shocked to find out that they actually do weight more then optional 18" OEM wheels because RUF is all about performance.
Old 08-26-2007, 10:22 PM   #9
Here is what Wayne from RUF said:
The RUF wheels are designed to remain true and round while dealing with the rigors of street driving (pot holes, lane dividers, etc), so weight was not the primary issue when they were made. The fronts are about 27lbs each and the rears are about 30lbs each. Light weight wheels are great for the race track, but often bend when used on a normal street.
Old 08-27-2007, 04:20 AM   #10
Indeed quite strong
I have here part of a catalog .xls file of Ruf. Come to see this my rear spacers must be 21mm instead of what I mentioned earlier.
Also these wheels are by a well know italian wheel manufacturer.
Don't remember exactly which one though.
I could check it out when I have a chance.
They are very strong.
Already brushed the side walk but damage was barely visible.
Unfortunately the info I have does not include the offsets.
Old 08-27-2007, 08:14 AM   #11
Spaced...here are my fronts and rears.
Old 08-27-2007, 08:19 AM   #12
Here are the fronts.
Old 08-27-2007, 11:35 AM   #13
WOW, I wonder how much the spacers weigh? They look like they would be heavy, adding even more weight to the cars hub. Sounds like you will loose some pick-up with all that extra weight on the flywheel too.
porsche986spyder is offline   Reply With Quote
Old 08-30-2007, 06:21 AM   #14
not quite
The RUF spacers are quite light.
Even counting that you have to put in studs with nuts (included). (the nuts weigh absolutely nothing!).
