Old 08-01-2007, 07:32 AM   #1
Tire size for 18x10 C. lightweight
About to buy Carrera Lightweights from Wheel Dynamics, size 18x8 & 18x10, and need some advice on the best tire size with Goodyear F1 G3-D3. I'm still a newbie when it comes to tires.
Is the best choice 225/40/18 and 265/35/18, or do I go with something wider on a 10" wheel? Tire Rack shows other available sizes 275/35(or 40)/18 and 285/35/18. 03 and my daily driver. At this point no auto-x but I do like a spirited drive after a long day at the office. Thanks!
2003 Boxster - Sold but not forgotten
timothy is offline   Reply With Quote
Old 08-01-2007, 09:11 AM   #2
i'd go with a 245/35 up front and 265/35 in back. the 285's get expensive and add to the understeer. the 245 / 265 combination is really neutral.
insite
'99 Boxster
3.4L Conversion
Old 08-01-2007, 09:54 AM   #3
Adding some 5mm or 7mm spacers in the back will heighten the aggressive stance of your boxster. I did it when I bought the same rims.
http://www.iwantaporsche.net/TOD/PICT0278.JPG
Old 08-01-2007, 10:02 AM   #4
265's are pretty skinny for a 10" wide wheel. 265's are meant for a 9" wide wheel. Might look kind of funny or provide funky wear/handling issues....I would go to at least 275's, but 285's is usually the width you want with a 10 in wheel. You might get some more understeer though as Insite mentioned, but are you tracking the car? If not that would be a non-issue.
Old 08-01-2007, 10:36 AM   #5
Seems when it comes to tire fitment everyone has a different opinion. I am not tracking the car but might try sometime.
So far nobody disagreed with 245/35 up front. Maybe 275 is a compromise on the rear. Is that a 275/35 or 275/40? Still open to other opinions. Thanks.
Old 08-01-2007, 10:59 AM   #6
The stock 18's on the boxster had 40 up front and 35's out back. I would stick with that tire side wall height. You could go 245 up front.
Old 08-01-2007, 12:09 PM   #7
a 265 is fine on a 10". looks ok, too (that's what i run).
insite
'99 Boxster
3.4L Conversion
Old 08-01-2007, 12:31 PM   #8
On my 9.5" OEM carrera lightweights, my 265 Toyos were pretty stretched... My new 275's protect the rim much better... you have to be careful with 285's as some may not fit. I also run 245's in the front, but they do rub under full lock... but im on PSS9's. Go with the 235 or 245 in the front and 275 in the rear you will be happy...
Lexington, KY Go CATS!
http://i187.photobucket.com/albums/x...s/DSCN0406.jpg
2001 986S... 3.6 swap (yep 7.2->7.8), PSS9's, GT3 seats, OEM 986 Carrera 5-spokes, and much more http://i187.photobucket.com/albums/x...me/burnout.gif
1987 928 S4 white on red and... dead
2004 Chevy Surburban... drinks gas like its cheap or something
easyc is offline   Reply With Quote
