Old 07-22-2007, 08:54 AM   #1
straight pipes exhaust cutout for 2000 S
Does anyone know if it is possible to install an exhaust cutout (either manually controlled via toggle switch or ideally electronically controlled to switch at a certain rpm).
I am looking for the best of both worlds, quiet when you want it (stock exhaust) or loud when you want it (straight pipes). I searched the forum and saw one good video of straight pipes but no mention of a cutout. Is such a thing possible on the boxster? (I've seen them on other cars).
Also I like the vw r32 exhaust and I believe ferraris and some lambos have a 2 stage exhaust? Has anyone seen a 2 stage type for the boxster (not like fabspeed or other where it is louder all the time).
Mike
saaber is offline   Reply With Quote
Old 07-22-2007, 09:24 AM   #2
i have 2 manually operated ones, well they are levers that you either open or close, or find a sweet spot somewhere in between.
there are 2 of them, and completely eliminate the exhaust, and can be closed of course for stock sound.
here is the link to what mine sounds like
http://video.tinypic.com/player.php?v=4ozu51h
another member on here has the electric ones, hell chime in hopefully. thats probably the vid. that you saw.
my cardomain/pictures page
Old 07-22-2007, 10:41 AM   #3
sounds good dude!
http://img412.imageshack.us/img412/9591/65zxg8pcz4.jpg
2002 Boxster S
Guards Red/Black
Hacks: De-Snorkeled, Clutch Swich, Debadged, Red Seatbelts, Painted Bumperettes,
986S Badge, EVO Intake, SuperSprint Exhaust, Fabspeed Cat Bypass
My Car: http://s220.photobucket.com/albums/dd74/zackwatt/
zackwatt is offline   Reply With Quote
Old 07-22-2007, 11:30 AM   #4
boggtown
Posts: n/a
I have exactly what your asking about, electronic exhaust cutouts. Yes, it can be done.
Exhaust Bypass Valves
Charles (badlanzhpe.com) is a good guy, tell him you have a boxster thats the same as Jon's and he will make sure you get the right stuff.
Old 07-22-2007, 12:05 PM   #5
Yea that's what I'm talking about!
The sound on both those cars is awesome. I love the adjustablility of the electric valves and that is exactly what I am looking for. I'm guessing there is probably some kind of pressure switch or other that can be used to open up the valves at a certain rpm, or at least "when you really get on it".
I have used $30 adjustable pressure switches to control when a watermister would squirt water on the outside of a turbo intercooler on saabs and it works great once you get it dialed in where you want it (switch was on turbo vacuum line and turned on at a certain psi of boost which was adjustable). There must be something similar that could be done here (maybe just have it in a vacuum line?).
Does the valve have "presets" such as 1/4, 1/8 etc. or do you just judge that yourself? Ideally the valves could be preset at 1/4 for example and then the pressure switch would kick it on at 4000 rpm or whatever you preferred. That would be sweet!
I skimmed the post you referred to and am really looking forward to reading it in detail!
Mike
Old 07-22-2007, 04:23 PM   #6
boggtown
Posts: n/a
Its fully adjustable. I think I counted 24 quick taps of the switch from full open to full closed so you could do it that way. I just count 4 seconds till its open all the way.
