Old 07-12-2007, 03:47 AM   #1
Question Blowing Smoke
I NEED HELP! My '99 Boxster is blowing a steady stream of white/gray smoke out the exhaust and my mechanics are stumped. they have changed the oil seperator, checked compression, and run through mosy everything. now they are telling me that it may be a bad valve at the crank case? any thoughts or suggestions would be appreciated.
albiemaster is offline   Reply With Quote
Old 07-14-2007, 07:13 AM   #2
question for those more expert but generally doesn't white smoke mean water/coolant while blueish gray means oil.
- ian
idheaton is offline   Reply With Quote
Old 07-14-2007, 08:32 AM   #3
Yeah, white smoke usually means coolant is mixing in with the oil. Not a good thing. I would put my money on a slipped cylinder sleeve considering the year.
Old 08-23-2024, 06:28 PM   #4
Having issues.
Hello and greetings.I just purchased a 1999 Porsche Boxster 82,000 miles on it was driving it noticed thick white smoke coming out the exhaust pipe so pulled in and stopped and left the car sit I want to see if when I came back it won’t start and leaking oil what could be my possible problems and ways to fix it do I have to pull the spark plugs and the O2 sensors and clean them so it gets ignition to start or is it a crack block or that blow a head
Mr.E is offline   Reply With Quote
