Old 07-23-2007, 10:33 PM   #1
Question What about the airbag light?
Your last update was about the hack, but did the airbag light turn off?
The reason I'm asking is because I was told by my dealer that I had the same problem. I paid about $600 dollars (P&L) to have the seat belt receptacle wiring harness replaced. After replacing the harness, they then told me that I had a faulty belt tensioner sensor on the passenger side. At the time, it sounded like a load of BS.
I didn't replace the latter sensor, but my light is still on. Should I replace the sensor or just not worry about it?
blackbox is offline   Reply With Quote
Old 07-24-2007, 06:48 AM   #2
Send a message via MSN to CJ_Boxster
Yeah the light is off now. Well i checked the system with a Durametric software tool and that told me that only the drivers side recepticle was faulty, so all i replaced was that... I didnt need all the wiring cause my car had that last update which i was able to tell since my car had the belts and all that stuff replace 2 years ago... just that the drivers side recepticle became crap. Can they show you the error on the device they are using to scan it?
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
