Old 06-30-2007, 02:44 PM   #1
Battery Charging
Do I need to take the battery out to charge it, or can I just put the charger on the posts with the battery connections connected? Thanks
LarryNC is offline   Reply With Quote
Old 06-30-2007, 03:40 PM   #2
I bought the battery tender which plugs into the cigarette lighter port. Very convenient. I keep it on during winter storage.
BTW: I also use a battery tender on my Harley davidson during the winter. It cost about $50 less than the porsche unit..... hmmmm...... same technology
'04 Black Boxster, 18" Carerra wheels
"If you're not living on the edge, you're taking up too much space."
wild1poet2 is offline   Reply With Quote
Old 07-05-2007, 09:54 AM   #3
You can charge the battery in the car, just dont try to use too much amperage as you will get overheating and gassing, I would also keep the cover off and give it some time on a slow charge.
Thom
'81 911 SC ROW = The Money Pit
'02 Boxster S = Daily Driver
thomschoon is offline   Reply With Quote
Old 07-06-2007, 03:42 AM   #4
I have used a trickle charge and a rapid charge on a large commercial battery charger and have suffered no ill effects on the boxster.
TargaRacer is offline   Reply With Quote
Old 07-06-2007, 05:10 AM   #5
Porscheectomy
Chargers that don't stop sending current through the battery when the capacity is full can damage the battery, any battery.
That's why the battery tender is such a great tool. It senses when the battery's at full capacity and stops. No trickling at all.
It's recommended to remove the electrical connection to the car when charging at the battery. Obviously you can't do that if you're charging through the lighter.
Old 07-06-2007, 07:52 AM   #6
Brucelee's Avatar
I have probably charged a Porsche battery over 100 times with a 12 amp charger.
Always left the battery connected, no issues.
Rich Belloff
Old 07-06-2007, 09:03 AM   #7
Porscheectomy
Scroll to about the bottom of this article.
http://www.procarcare.com/icarumba/resourcecenter/encyclopedia/icar_resourcecenter_encyclopedia_jumpstart.asp
There are plenty of sources that say about the same things about charging procedures and precautions.
