Old 05-31-2007, 05:29 PM   #3
There is an E-gas controller up under the dash, with a cable that runs to the pedal. This is what sends a signal to the DME to open the butterfly. These can, and do, go bad and will get rough, jumpy, and non linear. Yes, you can replace it and that will likely cure your driveability issues.
Patrick
