Old 05-06-2007, 08:34 PM   #1
996 twin turbo engine swap??
Hi,
Not that I am going to do it, but all of this talk of engine swapping got me thinking. If you where going to go through the trouble, why not put a twin turbo in the back?
Could it be done?
James
2002 S
jhandy is offline   Reply With Quote
Old 05-06-2007, 08:53 PM   #2
Send a message via AIM to 986rgt
Would not fit
The turbo and GT3 engines are completely different than our engines, different mounts and dimensions. If you saw a picture of a turbo motor you would understand. The amount of work to make it fit would be rediculous, although very cool.
Steve
986rgt is offline   Reply With Quote
Old 05-06-2007, 10:55 PM   #3
boggtown
Guest
Posts: n/a
hmmmm, GT3 engines are NA and made for narrow body cars... whats the deal with those?
Old 05-07-2007, 12:19 AM   #4
Send a message via AIM to blinkwatt
Someone overseas fit a GT3 engine in a 986,can't find the link to the website anywhere though.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 05-07-2007, 08:00 PM   #5
Just because the GT3 is NA does not mean it shares ANYTHING in common with our engines, or the powerplants in the "lesser" 996s. They are completely different cases and are far from a bolt in proposition.
Same holds true for a TT motor.
I'm sure it COULD be done, but I cant even begin to imagine the amount of work.
Patrick
Old 05-07-2007, 08:20 PM   #6
I've read somewhere the intake manifold won't fit under the boxster top as well.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 05-29-2007, 12:35 AM   #7
They have to make new engine mounts even for a 3.4L swap. And new fuel runners and a few other things.. A tt would be a big deal because you need to have a place to mount the intercooler (trunk?). It's not that big of deal tho just because the engine is not the same size, at least relative to a 3.4 or 3.6 swap.
-David
1995 Silverado V8 - Green/Tan (FOR SALE)
2000 Boxster S - Ocean Blue/Graphite Grey
2002 GSXR750 - Blue/White
http://www.darkoven.com/sig.jpg
David N. is offline   Reply With Quote
Old 05-29-2007, 09:18 AM   #8
I believe their dry slump lubrication systems are one of the biggest headaches for the swap
easyc is offline   Reply With Quote
