Old 05-06-2007, 05:41 PM   #1
Question ABS / TC lights came on
I was driving around today, a beautiful sunny day, and all of a sudden I noticed the ABS and TC lights came on. Any ideas what would cause this and how to reset it?
Rob
1999 Boxster Red/Blk
2007 BMW 328 Coupe Arctic/Tan
1993 Lotus Esprit SE Red/Tan
rteichman is offline   Reply With Quote
Old 05-06-2007, 05:49 PM   #2
A fault in one of the wheel speed sensors could be the cause. Check the ABS codes for any faults....
wvicary is offline   Reply With Quote
Old 05-06-2007, 06:10 PM   #3
I guess I have to take it into a shop. I don't know how to check the codes nor do I have any device to do it with
Old 05-06-2007, 07:30 PM   #4
When was the last time you flushed your Brake Fluid? If it's moisture laden and boils, this can set off a pressure sensor in the ABS. That's the problem here.
The Service Notes state:
  • Information light for TC
    -Lights for a lamp check when ignition is
    switched on
    - in conjunction with the indicator light in the rocker switch indicates that driving stability control is off
    - Indicates defect: TC is out of order
    - Lights together with the ABS warning light when there is an ABS fault.
    Warning light for ABS
    -Lights for a lamp check when ignition is switched on
    - If the ABS warning light lights up with the engine running, the ABS has switched off
    due to a fault.
Hope this helps...
Happy Motoring!... Jim'99
