Old 05-06-2007, 07:30 PM   #4
MNBoxster
Hi,
When was the last time you flushed your Brake Fluid? If it's moisture laden and boils, this can set off a pressure sensor in the ABS. That's the problem here.
The Service Notes state:
  • Information light for TC
    -Lights for a lamp check when ignition is
    switched on
    - in conjunction with the indicator light in the rocker switch indicates that driving stability control is off
    - Indicates defect: TC is out of order
    - Lights together with the ABS warning light when there is an ABS fault.
    Warning light for ABS
    -Lights for a lamp check when ignition is switched on
    - If the ABS warning light lights up with the engine running, the ABS has switched off
    due to a fault.
Hope this helps...
Happy Motoring!... Jim'99
