Old 08-06-2008, 05:26 PM   #81
OK, I have now run a full tank of fuel through the car, and things are now fixed. Yay!
Turns out (well, best educated guess as you can't confirm) is that my previous cluster was from a C4 Cabrio. This completely explains my "optimistic" fuel gauge readings.
To fix this, and/or to code your 996 cluster to recognize the top in motion light:
Using the PST2, log into the car. You will need DME and Immobilizer codes to do this. You must tell the car it is a 996, as otherwise it will not recognize the cluster. Then, code the cluster to be a 996 C2 Cab. You must then tell the car that it is a 986 again, and load the appropriate map into the DME.
Tholyoak can probably elaborate more on this than I can as he is the PST2 master. Thanks for the help!
Patrick
Old 08-06-2008, 05:31 PM   #82
Thumper's Avatar
Excellent news! Congrats!
Thumper is offline   Reply With Quote
Old 08-06-2008, 05:45 PM   #83
Patrick
Thanks, I will do this later this week or next.
Jake
http://www.jazmine.com/images/avatar.jpg
My FB has lots of pics
01 Speed Yellow Boxster S
- Tip
- PSE
- C4S Cluster with new style OBC
- 18" with 7mm rear spacers
- Litronics
- Fully de-ambered
- LED taillights
- Aluminium Pedals
- Integrated Garage Door Opener
- 986 emblem
- Yellow brake calipers with Brembo stickers
- Yellow center console
- Aerokit II wing & trunklid
- Eibach Pro springs
In memoriam: Black 935 Street
LowFlyR is offline   Reply With Quote
