Old 05-02-2007, 04:05 PM   #1
Send a message via AIM to blinkwatt
Bleeding the brakes w/o taking off the wheels.
I'm bleeding the brakes on my Boxster tommorow and think I may take a short-cut. My Carrera style wheels have pretty big gaps in between the spokes and I was able to get the tube over the bleeder nipple and fit the allen wrench on the bleeding valve(didn't turn it though as I'm bleeding the brakes tommorow). Does anyone see a problem with me bleeding the brakes and master cyclinder with the wheels on the car?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 05-02-2007, 04:11 PM   #2
Send a message via MSN to CJ_Boxster
you may have trouble getting the bleeder valve loose from the inside part of the brake caliper, Theres 2 bleeder valves per caliper.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 05-03-2007, 03:36 PM   #3
donv's Avatar
You really don't want to get brake fluid on paint. Other than that consideration, and the ability to work in there like CJ mentions and/or inspect the pads when you're doing the job, there's no real reason not to do it that way.
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
Old 05-03-2007, 05:29 PM   #4
Not the best idea. You dont want to risk brake fluid on the wheels, and I highly doubt you'd be able to get to the inner bleeder on the calipers.
Patrick
Old 05-03-2007, 06:37 PM   #5
Hi,
I wouldn't do it - Brake Fluid really ruins paint. An Allen Wrench? Since when? S/b a Closed-end, or preferably, a Flare Nut wrench (11mm).
As mentioned, the inner Bleed screws will likely pose some trouble with the wheels on...
Happy Motoring!... Jim'99
Old 05-03-2007, 07:08 PM   #6
Originally Posted by MNBoxster
Hi,
My mistake Jim, I meant open ended.
