Old 01-04-2010, 03:20 AM   #1
AM radio - CDR 210
I have the factory CDR-210 radio. when I play the AM side, it sounds horrible, no radio station sounds good, can't understand the announcer for any football / basketball / baseball game.
Anyone else had this problem? And any fix, other than yanking it and going to XM?
My Porsche mechanic drives a Saturn.
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
Old 01-04-2010, 01:56 PM   #2
schnellman's Avatar
Cdr 210
The CDR 210 in my '98 Box is a piece of crap. The only thing it's good for is the six disc CD player. Otherwise, I stick to the flat-six symphony.
Old 01-04-2010, 03:43 PM   #3
I had the same problem with my CDR-220. There is an antenna amplifier in the passenger B pillar. It seems that the electrical connectors are tempermental. I cleaned the connectors and put dielectric grease on them. My AM radio has worked perfectly ever since.
It's a rather easy repair... good luck!
K80Kid
K80Kid is offline   Reply With Quote
Old 01-04-2010, 03:44 PM   #4
What's this AM you speaketh of...
Actually, your issue is likely the antenna ground in your passenger side A-pillar. If you remove the trim (remove the visor and pry the trim away - making sure you release the hiddne clip at the bottom w/ a long screw-driver) you'll see a black plastic triangular tube ~ 3" long. Remove the screw connecting the wire from it to the A-pillar. Use some sandpaper and sand off the paint and primer until you have just metal. Then you can put a little dielectric grease on the spot or just refasten the screw/wire. I'd test the radio before you reinstall the trim to make sure you sanded enough off. CAUTION: when reinstalling the trim and visor, DO NOT over-tighten the the two outboard Torx (T-30 ? IIRC) screws . Just barely hand tight is fine. Don't ask how I know... though I wrote up a solution for that, it's best if you do not need it
There are probably directions w/ pictures in here somewhere if you search on AM or radio reception...
Old 06-07-2010, 12:11 AM   #5
I was thought that Your player was being in scrap mode. So you have checked it that You have played the CD player as well. If You will still persist that issue then replace it and get it new inplace of it.
r4 ds
reojohn285 is offline   Reply With Quote
Old 11-23-2018, 06:40 AM   #6
Tailwind's Avatar
That's mainly why I bought mine
'99 986 Base
2010 Golf TDI
'74 914 2.0
'56 356A
Tailwind is offline   Reply With Quote
HTML code is Off
