Old 08-19-2018, 06:19 PM   #1
Boxster headlight wont lock in.
So I bought some new headlights for my 2004 Porsche Boxster. I've tried everything to get them to "POP" into place. The 5mm socket just turns under tension and dosen't lock in. I need help.
Headlights:
https://www.********************************************** **************/pn/AL-98663113114
Bee_Sully is offline   Reply With Quote
Old 08-22-2018, 01:39 AM   #2
Your lock bar may be stripped.
Old 08-22-2018, 04:26 AM   #3
Who's askin'?
maytag's Avatar
Agreed. Or the tool, if you're using the one from the factory tool kit. Mine was cracked, though I couldn't see it, and it just turned on the shaft.
Old 08-22-2018, 05:23 PM   #4
"50 Years of 550 Spyder"
10/10ths's Avatar
The tool kit tool is the problem...
....try a 5mm socket on a ratchet.
Old 08-22-2018, 05:47 PM   #5
2003 S, Arctic Silver, M6
paulofto's Avatar
+1 ... my right side cluster needs a 5mm socket, the tool kit socket just doesn't work. The left side works with both.
HTML code is Off
