Old 07-15-2018, 11:09 AM   #1
Oil Pressure Relief Valve - 2000 Boxster 2.7l
Where is the oil pressure relief valve found from underneath the vehicle?
Thanks for the help.
jmc1024 is offline   Reply With Quote
Old 07-15-2018, 11:17 AM   #2
Old 07-15-2018, 01:21 PM   #3
Thank you! And the oil pressure relief valve (plunger/spring) has been replaced!
Old 07-16-2018, 04:57 AM   #4
1998 Boxster Silver/Red
I'll be doing that come Fall. Did you replace the piston/spring with the oil absent from the vehicle, maybe as part of an oil change? Or, with the pan full, did you just unscrew the bolt and replace the parts? Any tips or tricks?
Thank you.
1998 Porsche Boxster
Old 07-16-2018, 07:42 AM   #5
Thank you.
Only a very small amount (one cup or so) drains out of the oil pump while doing this. Be sure to use a new sealing washer on the plug and torque it to spec.
Old 07-16-2018, 09:36 AM   #6
Motorist & Coffee Drinker
78F350's Avatar
I installed one of those recently. If you trust the internet to provide torque specs, the internet is now telling you:
"Tightening torque for pressure relief valve 25 Nm (19 ftlb.)"
HTML code is Off
