Old 11-24-2014, 12:13 PM   #1
04 Boxster S Connector
Could somebody identify this connector, please? Is underneath of the driver`s rear tire side(left side). The cable is tie together with the ABS cable. I have a ABS and PSM light on, could be this cable the problem? Also I have the brake lights on too. Thanks in advance
. Also it has these numbers on it: r n o then 99970227440 then >EPDM<
carlosnolasco is offline   Reply With Quote
Old 11-24-2014, 12:20 PM   #2
woodsman's Avatar
Does your car have litronic headlights? If so it may be the plug for a height sensor which is located on the lower control arm at the FR and RR LEFT side only.
Old 11-24-2014, 12:46 PM   #3
woodsman's Avatar
The plug bolted to the strut/ wheel bearing carrier is for the wheel speed-sensor.
Old 11-24-2014, 01:00 PM   #4
woodsman's Avatar
I suggest that you post in the 'general discussion' or 'technical' sections as you will get more response...
Old 11-24-2014, 02:21 PM   #5
04 boxster S connector
I posted the question and the pictures in the general question, thanks.
HTML code is Off
