Old 02-24-2007, 05:40 PM   #1
Send a message via AIM to blinkwatt
Found very small pieces of metal in oil filter housing
Just as the title says. I was changing the oil and while I was cleaning the oil filter housing cover I found very small pieces of metal or what I think is metal. I couldn't find any in the oil filter,which seemed weird. Anyone else have this happen?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 02-26-2007, 10:57 AM   #2
Bump,I know plenty of people on this board have changed their own oil before.
Old 02-26-2007, 11:00 AM   #3
Send a message via MSN to CJ_Boxster
Have you checked your compression or oil pressure in the past? Might be a good idea to check it again. When i had brass/gold looking flakes in my oil on my MY65 912, it was result of a desolving brass valve guide. Explained all the tapping in my driverside head.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 02-26-2007, 11:08 AM   #4
How do I do that?
Old 02-26-2007, 11:18 AM   #5
edevlin's Avatar
I recently saw what lookes like small metal flakes in my oil when I changed it. Car has been running like a top. I will send in a sample of oil as per the recommendations of other members to have it analyzed.
Ed
My Car Webpage
2000 2.7L Boxster 102K; TTP intake, headers, high-flow cats; Dansk high-flow muffler; Autothority ECU chip; TechnoTorque 2; Bilstein coilovers; Racing Dynamics strut brace; stress-bar suspension kit; Aasco lightweight flywheel, B&M short shiftkit; 18" wheels; spare tire delete; OEM GT3 seats; JL audio speakers and subwoofer; Alpine PDX-5/PDX-2 amps; Kenwood DNX8120 CD/DVD/Nav; litronics, deambered
edevlin is offline   Reply With Quote
Old 02-26-2007, 11:32 AM   #6
Ed
Hey edevlin,
I only found the small flakes in my oil filter housing cover it seemed. I couldn't find it on the filter or in the oil,weird huh? Be sure you post what they say about your oil.
Old 02-26-2007, 11:49 AM   #7
Originally Posted by blinkwatt
How do I do that?
Pull all the ignition coils and sparkplugs out, disable the fuel pump so it isnt pushing fuel into the cyclindars while you do this. Then screw in the compression tester hose into one of the sparkplug fittings on the head. Then have someone sit in the drivers seat, Hold the accelerator down all the way while they crank the engine over 4-5 times. Then check the vacum gauge on the compression tester and write down the ammount of Vacum the gauge is reading from that cyclindar, Now do that to all the cyclindars.
Ask MNboxster for the limits of how close the compression should be from one cyclindar to the next.
Carlos J Cazares
