Old 06-19-2023, 04:15 AM   #21
I would use tape designed to seal off deck joists. It is the stickiest tape I have ever found and specifically designed for use in damp environments.
subieworx is offline   Reply With Quote
Old 04-10-2024, 04:54 AM   #22
Would prefer to use these plugs but they won't post to Australia!
Kurtmanfoz is offline   Reply With Quote
Old 04-11-2024, 12:13 AM   #23
Here's an stl I found on thingiverse if you or somebody you know can print ABS or PETG.
Or you can use some commercial 3D printing solution like shapeways.
I've not tried these myself but I will later this summer.
Makrilli is online now   Reply With Quote
Tags
blend door , diy , foam , hvac , vent
