Old 12-08-2021, 01:01 PM   #61
A close approximation of the crank journal sizes could be obtained by torquing empty new bearing shells in the rod and mains carrier, then inside mic them.
Old 12-09-2021, 03:08 AM   #62
Good call
OldManMo is offline   Reply With Quote
Old 12-10-2021, 09:18 AM   #63
It`s even easier to measure the clearance with plastigauge. You can check the old and new set and compare.
Old 12-10-2021, 03:01 PM   #64
OldManMo you inspired me to clean up my souvenir piston from my engine before it was rebuilt as a 3.6. A week in a gallon of carburetor cleaner was all it took! Keep posting updates, I love following your progress!
Old 12-10-2021, 04:57 PM   #65
So, my question is: how do you use this when the bolts have to be torqued and then taken to the proper angle--and are one-time use?
-H. L. Mencken
Newsguy is offline   Reply With Quote
Old 12-10-2021, 05:24 PM   #66
Easy: you use the old bolts for plastigauging/mic-ing and use the new ones for reassembly.
Old 12-12-2021, 02:56 AM   #67
Thanks PaulE and others for the words of encouragement and really makes my day that I am helping others. My son and I are having lots of fun so far learning and seeing the progress. We had a great evening in the other day watching Jake’s DVDs with a bag of popcorn and a slushy. Me more than him mins you
Nothing so far has been daunting but that said I do believe I did the tear down at the right time before any damage.
Will share more progress in the next few days
Thank you all
Old 12-13-2021, 08:40 AM   #68
So first round of cleaning for the carrier, crank and IMS
Before is yuk
After is much better and can really see what the situation is. Still not finished with the carrier though
Crank needs a little more work and I want a Machine Shop to check it. So will look to get it only micro polished
Old 12-13-2021, 08:43 AM   #69
I use an Ultrasonic bath to do the cleaning and interesting what you fine on the bottom. This is from the Crank, which wasnt bad even though its what is all that.
I didnt take a picture after the carrier but there were loads of little bits of plastic once cleaning had finished
Old 12-13-2021, 10:57 AM   #70
Brilliant, very interesting thread and how you document the progress. Thank you and keep up the fantastic work
2001 996 C2 Manual
Old 12-24-2021, 11:13 AM   #71
May I ask, the parts that where mediablasted, eg the gearbox. Did you clear coat them after? Any trick to make them stay that clean?
Old 12-26-2021, 02:41 PM   #72
Hi Robert986
Different parts had a different finish. For the gearbox, I didn’t mediablast as it was too big for my machine, but I cleaned it with degreaser, then wire bushes, then used a lot of carb and brake cleaner, scotch pads, then I gave it a light coat of alloy wheel silver paint. One year it is still holding up. With hindsight, I probably sent this out to be media and vapour blasted then had a anti-corrosion coating applied.
For other parts such as suspension parts I did media blast with soda and fine glass beads (taken care for smooth finished areas) then applied either silver alloy paint or anti-corrosion coating. For the exhaust,, this was a couple of hours spent using a fine scotch brite wheel then a polishing wheel with a polishing compound like autosol
I need to do the front suspension and brakes so I will share what I do, again not to say this is the “right” way to do this but just what I did/do
Old 02-25-2022, 12:24 PM   #73
Latest
Hi all
I know, its been ages. Lots of reasons, Christmas, holidays, work, home, waiting on parts, waiting on parts, waiting on funds and so on
Spent most of the time since my last post cleaning, measuring, investigating, learning while I waited to order and receive parts. I should hopefully be in a position to start the rebuild in the next month or so. Dont get me wrong, I currently have a small mountain of nice new engine parts, but still quite a bit more to get.
While cleaning the many parts in the ultrasonic tank, I could clearly see particulates fallen to bottom. These were mostly plastic from the chain guides and some pieces of carbon. There was however, lots of pieces and they came out from almost everything that was cleaned, Crank, Cams, lifters, lifter housing, IMS itself once the bearing was removed.
All honesty, I am not sure I didn't find lots of damage as it does look (and maybe I am fooling myself) as I caught it in time
So while I get ready to start the rebuild here is some photos from what has been done so far.
In almost all cases parts started in the tank, then cleaned and polished by hand, then back to the tank, then cleaned with carb cleaner, then back into the tank, then polished by hand again, then back to the tank...well you get it. BTW, I dont mind cleaning and polishing by hand, I find it therapeutic and I get up close and personal with the part
Old 02-25-2022, 12:26 PM   #74
The IMS took lots of nice gentle work but ha come up nice. Lots of nasty sludge came out from the inside but more so when I used a bottle brush to get to the end
Will still go through one more round of cleaning before I fit it
Old 02-25-2022, 12:32 PM   #75
Crank took some time also and I found a lot of sludge and a small piece of plastic in the oilways. The journals where hand polished. I used 10,000 grit wet and dry on the heavily soiled journals. The specs where in line with what is published else where on the net. It has been crack tested, but will have it tested once more and run through final cleaning just before fitting
This is how I started
after a few round in the ultrasonic bath
And a number of hours later by hand
Old 02-25-2022, 12:37 PM   #76
Crank carrier also had the tank and hand polishing treatment. Had a strange one here as I reassembled without the bearing to torque to measure the roundness of the bearing seats and was seeing about 0.01-0.02mm differences across the face. I found that there were deposits of carbon/oil/stuff that I didn't notice the first time.
Spent some more time cleaning and polishing the seats and was seeing, sometimes only 0.01mm differences. Didn't think that the build up could be as much as that, but it could have dried on when I removed the bearing I guess.
You can see it a little in the phot below between the first seat on the left and the next ones
Old 02-25-2022, 12:41 PM   #77
The cams also had a thick (well less than 0.01mm) build up. Took a while and again by hand, though I did use a fine glass beads on shaft between the bearings and cams but they cam up nice
lifter carrier also came up nice though this had a lot of deposits at the bottom of the ultrasonic bath when cleaned. Still needs a little more work and polishing
Old 02-25-2022, 12:43 PM   #78
lots of other parts scrubbed up well
Old 02-25-2022, 12:46 PM   #79
also got some new pistons
And will be replacing the rod bushings as there was noticeable play and didn't like the look of them.
I assume these are pressed in as per normal, nothing special needed with them?
Old 02-26-2022, 11:29 AM   #80
Love watching the progress. What type of ultrasonic machine do you use?
palindrome is offline   Reply With Quote
Tags
986 boxster , engine removal , rebuild
