Old 12-09-2021, 04:08 AM   #1
A close approximation of the crank journal sizes could be obtained by torquing empty new bearing shells in the rod and mains carrier, then inside mic them.
Good call
OldManMo is offline   Reply With Quote
Old 12-10-2021, 10:18 AM   #2
It`s even easier to measure the clearance with plastigauge. You can check the old and new set and compare.
Old 12-10-2021, 05:57 PM   #3
So, my question is: how do you use this when the bolts have to be torqued and then taken to the proper angle--and are one-time use?
-H. L. Mencken
Old 12-10-2021, 06:24 PM   #4
Easy: you use the old bolts for plastigauging/mic-ing and use the new ones for reassembly.
Tags
986 boxster , engine removal , rebuild
