Old 08-13-2021, 08:17 AM   #1
Chain Tensioner Replacement
Here's the first detailed chain tensioner replacement video I'm aware of. After driving for a week it has definitely helped to eliminate the dreaded chain rattle on startup. Unfortunately I waited too long to do it and will need to replace the chain rails as well. That will be the next major project. But for now...
https://youtu.be/7LsKjJg5ox8
1998 Boxster
2015 BMW M4 Dinan Stage 3
2016 BMW S1000XR
2015 Ninja 300
TTGator is offline   Reply With Quote
Old 08-13-2021, 12:27 PM   #2
1998 Boxster Silver/Red
Another great vid! Thanks.
Other than requiring some patience... that is a nice DIY.
I thought there were three (3) tensioners. No?
1998 Porsche Boxster
Old 08-13-2021, 01:50 PM   #3
Yes there are 3. Check out my previous video for more background/details.
https://youtu.be/kei8ffcxjXQ
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
Old 08-13-2021, 03:00 PM   #4
Thanks for making this! I'm looking forward to the chain guide video.
gonz is online now   Reply With Quote
Old 08-14-2021, 02:29 PM   #5
there is another tensioner on top next to the AC compressor. It may be part of the issue also,.? Frank
Old 08-14-2021, 02:30 PM   #6
Yes, I talked about that one in the first video.
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
Old 08-14-2021, 09:28 PM   #7
Great video, thanx
P.S. eagerly waiting for the video of the Variocam pads change...
Boxster 2.7 2001 Manual
Old 08-15-2021, 02:52 AM   #8
Originally Posted by pilot4fn View Post
Great video, thanx
You’re welcome! Hope you’re a subscriber now 😉
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
Old 08-16-2021, 04:41 AM   #9
Thank you for taking the time to share your mechanical adventures and help the rest of us determine if we want to follow you down a particular path.
Did you measured the cam deviations before / after the tensioner change?
junglegreen is offline   Reply With Quote
Old 08-16-2021, 04:48 AM   #10
I did not do the before, but I will be doing the after in a little bit
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
Old 08-16-2021, 05:17 AM   #11
01 Seal Gray 986 S
bg305's Avatar
Do you know which chain guide components you are going to be replacing? I started hearing chain noise a couple of months ago and stopped driving the car. I decided I wanted a lift to make the job easier since there was a high probability I would be pulling the engine, and I see myself using it hopefully for many years in the future. My cam deviations on bank 2 are off a bit more than 9 degrees. My hope is to replace the actuator guides and not have to split the block. But I figure I'm going to learn a lot once I get the process started. I get back from vacation this week, there was some delays on the lift I ordered because it was a brand new model from Stratus but I think it should be in my garage in the next week and a half and I'm going to get started.
Do you know how far deep your project's going? Are you attempting with the engine in and are you only doing the actuator guides or tearing everything apart?
bg305 is offline   Reply With Quote
Old 08-16-2021, 05:19 AM   #12
I'm not sure if the guides I need to replace are the "actuator guides" or not, but I'm told they can be reached by removing the cam cover without needing to take the engine out. I'm also waiting until I get my lift haha. Moving into the new house this coming weekend and then will order the lift, so I'm probably 3-4 weeks out.
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
Old 08-16-2021, 08:33 AM   #13
They can be done with the engine in the car, I did it...but it caused a lot of cursing.
dsallean is offline   Reply With Quote
Old 08-16-2021, 09:01 AM   #14
Super………..
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
