-   -   Clutch pedal stiff (http://986forum.com/forums/diy-project-guides/77998-clutch-pedal-stiff.html)
OldMacTech 06-08-2020 07:04 PM
Clutch pedal stiff
97 base model, doesn’t get driven much. Went for a drive last pm and the clutch pedal is much stiffer than it used to be. My wife drives it occasionally and I doubt she could now. I read some stuff that it my be a clutch return spring or slave cylinder. Seems the slave would have no pedal not harder but please enlighten me.
Shifts fine,drives well other than the pedal.
JayG 06-09-2020 02:45 PM
Most likely the clutch booster spring broke. Not an uncommon thing
Its not hard to replace. There are a few threads here and on rennlist
do a search for "clutch booster spring", "clutch booster", "clutch spring", or "booster spring"
you can buy the assembly or replace the spring in the assembly
