Old 02-07-2020, 08:18 PM   #1
DIY: Headlight Switch replacement
Just replaced the headlight switch on my 1998 Boxster. The symptom was my left tail light would usually not work and it was not the bulbs. Made another DIY, hope it helps someone! Very easy to do, should take about 20 minutes.
https://youtu.be/j9gU2Vx7pFw
1998 Boxster
2015 BMW M4 Dinan Stage 3
2016 BMW S1000XR
2015 Ninja 300
TTGator is offline   Reply With Quote
Old 02-07-2020, 09:28 PM   #2
Not a bad job at all. If one takes their failing switch apart they'll wonder how it ever worked that great to begin with. Contacts are flimsy at best. I did mine...cleaned it and messed with it a bit. It worked much better but I still replaced it about a year later when I came across a gently used on on the forum.
The switch in my 911 is starting to show signs....not electrically but mechanically. It offers little resistance when turning off/on.
Old 02-08-2020, 04:25 AM   #3
Yes, my old switch had very little resistance too. In fact, I could turn it to the two full left positions without pulling it out!
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
Old 02-08-2020, 04:17 PM   #4
That’s what mine is doing as well. Switch it still working though.
Old 02-08-2020, 04:35 PM   #5
Very good work on your video!
Old 02-08-2020, 04:50 PM   #6
Thanks!!!!
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
