Old 08-23-2019, 01:02 PM   #1
DIY: Change Thermostat and Water Pump
Did this as preventative maintenance when I had to replace a leaking coolant tank:
https://youtu.be/5uwgCrYLGTc
1998 Boxster
2015 BMW M4 Dinan Stage 3
2016 BMW S1000XR
2015 Ninja 300
TTGator is offline   Reply With Quote
Old 01-30-2024, 12:59 PM   #2
97 Boxster 986 I just took my water pump off and didn’t keep track of the bolts. I’ve got one .75”, five 1” and two 1.25” bolts. From my research the two longer bolts go on the holes with alignment guide on the pump. Any thoughts about the .75” bolt?
Bush Pilot is offline   Reply With Quote
Old 01-30-2024, 08:51 PM   #3
The .75” bolt I took off wasn’t part of the water pump assembly. Please ignore this post.
