DIY: Change Thermostat and Water Pump
Did this as preventative maintenance when I had to replace a leaking coolant tank:
https://youtu.be/5uwgCrYLGTc |
97 Boxster 986 I just took my water pump off and didn’t keep track of the bolts. I’ve got one .75”, five 1” and two 1.25” bolts. From my research the two longer bolts go on the holes with alignment guide on the pump. Any thoughts about the .75” bolt?
| All times are GMT -8. The time now is 05:28 PM. |
