Old 05-05-2018, 09:15 AM   #1
chemistone82's Avatar
Whining noise at 2900rpm
I’d appreciate some advice. Thanks in advance. I have a high pitch whine above 2900 rpms. Here’s what I know so far
Definitely in the engine bay.
Alternator is charging at 14.1 V
It’s not the SAI system
Doesn’t seem to affect the running of the car
Any ideas what this could be?
98 2.5L 5 speed
chemistone82 is offline   Reply With Quote
Old 05-06-2018, 06:26 AM   #2
1998 Boxster Silver/Red
98 2.5L 5 speed
Anyone in the passenger seat? My wife has been known to make whining sounds ~5500RPM. YMMV.
1998 Porsche Boxster
Old 05-06-2018, 06:39 AM   #3
Cunningr's Avatar
Apart from wife, i have one that whines while sitting on couch even, could be a water pump bearing or other bearing in the main belt ie ac pump, tensioner.
Old 05-06-2018, 10:55 AM   #4
BYprodriver's Avatar
98 2.5L 5 speed
Remove the serpentine belt to see if the noise goes away, if it does the cause is a noisy pulley or water pump. If you detect any looseness or leakage from water pump replace with a new Pierburg pump.
Old 05-06-2018, 09:26 PM   #5
AZ986S's Avatar
Power steering pump? Low on fluid?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 05-17-2018, 11:08 AM   #6
Well got it diagnosed at the shop. Bad belt tensioner and water pump.
Old 05-17-2018, 02:29 PM   #7
Cunningr's Avatar
Well at least that is a common issue, and sounds like you found it before it imploded inside.
