Old 02-09-2018, 08:30 AM   #1
Shellback85's Avatar
RFID Push Button Start for 03 base model Boxster.
I'd be interested to know if anyone has installed an RFID Push Button on their Boxster. Would really appreciate hearing about how it either worked out, or didn't work out for you, and if it did maybe a list of the equipment you used. Thanks.
Shellback85 is offline   Reply With Quote
Old 10-01-2018, 02:30 PM   #2
Reviving this slightly old thread I have found a company called Advanced Keys with item number AK - 105B for $369.99 I am going to try and install to replace the ignition problem permanently. Having found my steering lock assembly is bad I will remove it completely and go via push button with both RFID and the immobilizer still intact for security. Will keep posted as soon as kit arrives and will detail installation as I go.
RE2Master is offline   Reply With Quote
Old 10-02-2018, 03:46 AM   #3
1998 Boxster Silver/Red
I'd be most interested in the outcome.
Are you going to install it by yourself? Or, are you outsourcng it?
I'm looking forward to your install narrative.
Good morning.
1998 Porsche Boxster
Tags
dyi push button start
