Old 11-12-2017, 04:43 PM   #1
kk2002s's Avatar
Low Speed Fan Resistor Alternative
So right side radiator fan wasn't running the other day as the left side kicked on. Didn't work turning AC on, so I jumped the low speed relay (#21 for right side low - Bentley's has a typo for this) and it still did not operate. I jumped the high speed (#22 for right side high) and the fan worked so it must be the low speed Resistor.
$120 to replace just the resistor and no aftermarket - Are You Kidding me.
$150 to replace the fan with resistor, now that actually seems reasonable.
I'm so cheap so!!!
There are articles on buying an air cooled resistor (.5 Ohm, 100 watt) - $9.95
So I bought (2) for when the left side goes out or I screw up
I was going to have to splice the (3) wires (All Green, Green White strip, All White) If I bought the Porsche resistor so this work was the same
Mounting was the question. There is a metal tab at the back of the chamber where the fan was. I had to simply drill a hole through the plastic, it was at the perfect spot to mount one corner.
I used #8 1-1/4 stainless steel bolts, nylon locking nuts (2/bolt) and plastic wire hangers.
Wiring - All Green wire goes to ones side
- Green/White strip wire and All White wire both connect to the other side
I did not soldier. I used crimp fittings and heat shrink tubing. I may pay for that with time.
I mounted and used a backer for the other hole. I had the inner fender off so I could get to this area easily.
And the final product from the front
Seal Grey
Old 11-12-2017, 07:35 PM   #2
On the slippery slope
JayG's Avatar
Nice writeup!
2004 996 Targa Tip
Instructor - San Diego region
Old 11-17-2017, 08:49 PM   #3
Did the same fix, very cost effective and so far dependable through the summer after 5,000 miles. If I recall, I used 50w registers slightly below 0.5ohm, and the original clamp could wrap it around just like factory install, after cutting off the mount ears.
Also added a toggle switch to manually turn on/ off the fan, so I got full control to keep the engine cool consistently in heavy traffic during summer, plus easy to diagnosis for bad fan/ register with a flip of the switch.
Old 11-18-2017, 11:52 AM   #4
If you are concerned about summer heat in slow /no-go traffic. suggest the simple mod of relocating the Temp sensor for the engine compartment purge fan.If you reposition it closer to the cylinder head , it will turn on the exhaust fan sooner/longer.
Old 06-11-2018, 10:57 AM   #5
Stiglitz's Avatar
Ready to install resistor
I'm about to install a replacement resistor for rad fan.
Is 100w 1 ohm resistor ok?
Currently not running,at least one lead is corroded off the original.
Can't justify $150 for a $5 resistor
Thx in advance
2002 base
Stiglitz is offline   Reply With Quote
Old 06-12-2018, 02:29 AM   #6
Oggie's Avatar
The original resistor is about 0.5 ohm. If you have a couple of 1 ohm resistors, put them in parallel and you will be fine.
I replaced mine with a single 0.5 ohm (0.5R) 100W resistor about 6 months ago and it has been working fine ever since.
'99 base Boxster (Arena Red Metallic/Savanna Beige)
'02 911 Carerra Cabriolet (Arctic Silver/Metropole Blue)
Oggie is offline   Reply With Quote
Old 06-12-2018, 04:29 AM   #7
Stiglitz's Avatar
Thanks!
I ordered two, so I'll parallel them. Hope to have them tomorrow. Makes me nervous not having them working, especially with weather in the 90's! (Central Florida).
Thx Again!
Old 06-12-2018, 07:33 AM   #8
kk2002s's Avatar
So the product I used was that Arcol HS 100 R5 J as pictured. it is .5 Ohm therefore I only used 1
The fan works as expected for low speed
I did buy 2 so I was ready for the other fan's low speed to die at some point.
Seal Grey
Old 06-12-2018, 04:28 PM   #9
Stiglitz's Avatar
Installed in parallel, pretty easy.
Did not even have to pull the wheel.
I'll post some pics tomorrow
Working as expected
Old 07-24-2018, 07:32 AM   #10
Stiglitz's Avatar
Old 09-08-2019, 05:28 PM   #11
Motorist & Coffee Drinker
78F350's Avatar
Just bumping the topic for a good, simple repair.
One of my '99s had been running a little hot for a while and I thought it was just from debris in the radiators. Over the course of a year, I cleaned the radiators and replaced the water pump (It was due anyway) It still was running on the 0 in 180 where my other cars would be on the 8. Then, on a long drive it got worse and the AC was blowing warm. BOTH radiator fans had quit working and I had probably been driving for a long time with only one.
I still had a pair of these resistors (if parts are cheap, I buy extras.) from when I did it a few years ago on another car. Once I recognized the problem it was a quick and easy fix.
