Old 08-15-2017, 06:45 AM   #1
Seat belt retracted all the way-DIY fix
My very tall very old friend yanked and tugged at the wrong end of the belt and it became stuck in the fully retracted position with only about 1/4 inch of play in the belt.
Here is what I did to fix it.
Remove the interior panel-it just clicks in under the rubber door seal so it will pop right out. With that pulled out of the way (I left the top fastener attached) you'll see a black plastic cover over the belt reel. That pops off as well and you'll see 3 yellow plastic wheels with teeth. At the top there is a white plastic lever. Push that lever to disengage the lock and tug the belt. After several tries I got the belt to retract, so now it works as usual. Button it all together, snap the panel back and go drive. Good luck.
Tom
tlc356 is offline   Reply With Quote
